Ultra-low VCE(sat) NPN and PNP bipolar transistors from Diodes Incorporated maximize power density and efficiency in compact automotive designs
Diodes DXTN78 DXTN80 DXTP78 DXTP80
Diodes Incorporated announces an expansion of its automotive-compliant bipolar transistor portfolio with the introduction of the DXTN/P 78Q & 80Q series. These ultra-low VCE(sat) NPN and PNP transistors deliver industry-leading conduction efficiency and thermal performance, optimized for demanding automotive power switching and control.
Diodes - DXTN78, DXTN80, DXTP78, DXTP80
The twelve high-performance devices support a broad voltage range, making them suitable for 12 V, 24 V, and 48 V automotive systems. They are ideal for gate driving MOSFETs and IGBTs, power line and load switching, low-dropout (LDO) voltage regulation, DC-DC conversion, and driving motors, solenoids, relays, and actuators. Rated for continuous operation up to +175 °C, and offering high ESD robustness (HBM 4 kV, CDM 1 kV), they provide reliable operation in harsh automotive environments.
Housed in the ultra-compact PowerDI3333-8 package (just 3.3 mm × 3.3 mm), these devices cut PCB footprint by up to 75% versus traditional SOT223, freeing space for additional functionality. A large underside heatsink delivers ultra-low thermal resistance (RθJL) of 4.2 °C/W. The side-wall plateable (SWP) feature improves automated optical inspection (AOI) visibility and strengthens solder joints. This enhances quality assurance, reduces manual inspection, and supports efficient, reliable manufacturing.
Both series span BVCEO ratings from 30 V to 100 V and deliver robust current handling. The DXTN/P 80Q series provides extra headroom for demanding designs, with continuous ratings up to 10 A and peak pulse capability of 20 A. Ultra-low saturation voltage (just 17 mV at 1 A) and an on-state resistance as low as 12 mΩ minimize conduction losses, enabling cooler operation and higher efficiency. This helps designers cut conduction losses by up to 50% versus previous generations, reducing heat and easing thermal management.
The DXTN/P 78Q series is now available from between $0.19 and $0.21, and the DXTN/P 80Q is available from between $0.20 and $0.22; both in 6,000-piece quantities. Standard compliance versions, the DXTN/P 78 & 80 series, are also available and suitable for industrial and commercial applications.
