Diodes Incorporated expands its innovative load switch portfolio with the introduction of DML1012ALDSQ, an automotive-compliant low drain-source on-resistance (RDS(ON)) N-channel MOSFET smart load switch. The device is ideal for reliable power sequencing and power rail control in automotive applications that include advanced driver-assistance systems (ADAS), infotainment platforms, and display clusters.
The smart load switch features an input voltage range of 0.8 V to 4 V, allowing use in numerous subsystem power rail domains. The ultra-low RDS(ON) of 8 mΩ (max.) minimizes on-state losses and reduces heat generation in and around the device. A junction-to-case thermal resistance (RθJC) of 8 °C/W enables up to 6 A of continuous output current. The device also features a low quiescent current, improving efficiency during power gating and minimizing standby power consumption. In addition, the enable control pin provides precise, microcontroller-driven power sequencing.
The DML1012ALDSQ incorporates several key protection features, allowing engineers to reduce PCB area and time to market, as compared with a discrete solution. The device minimizes inrush current by controlling the output voltage slew rate during start-up, which benefits system stability. Integrated quick output discharge ensures downstream components are fully discharged during shutdown. In addition, undervoltage lockout (UVLO) disables system function when the supply voltage falls below a safe threshold, ensuring predictable behavior and stable supply conditions.
The DML1012ALDSQ is available in the V-DFN3030-8 (Type R) (3 mm × 3 mm) package and priced from $0.17 in 1,000-piece quantities. A standard compliance version, the DML1012ALDS, is available for industrial and commercial applications.
