Diodes Incorporated introduces its first automotive-compliant 3D linear Hall effect sensor. The AH4930Q detects the magnetic field in the X, Y, and Z directions, allowing for reliable and high-precision contactless rotary motion and proximity ...
VLSI Solution announces VS1073, the world's most advanced audio codec coprocessor with earphone amplifier. The VS1073 IC is a low-power mixed-signal audio coprocessor that can encode and decode a myriad of different formats. It can greatly ...
Toshiba Electronics Europe has launched a gate driver photocoupler suitable for driving silicon carbide (SiC) MOSFETs in industrial equipment like industrial inverters, uninterruptible power supplies (UPS), and photovoltaic (PV) inverters, which ...
Fully integrated protected GaN ICs with bi-directional loss-less current sensing delivers 4% higher efficiency, 15% lower system cost 40% smaller footprint. Navitas Semiconductor has announced a new family of GaNSense Motor Drive ICs targeting home ...
Vishay Intertechnology introduced the industry’s first AEC-Q100 qualified rectangular ambient light sensor. The Vishay Semiconductors VEML4031X00 features an ALS and highly sensitive IR photodiode in an opaque 4.38 mm by 1.45 mm surface-mount ...
Integrated low-power analog peripherals reduce design costs and complexity Devices designed for capturing rapidly changing analog signals must respond quickly while consuming minimal power, especially in battery-operated applications. To address ...
Manufacturers of cutting-edge audio equipment constantly seek to enhance sound quality while also meeting the growing demand for compact, lightweight, more integrated, and energy-efficient designs. At the same time, they must ensure seamless ...
Texas Instruments (TI) introduced the world's smallest MCU, expanding its comprehensive Arm Cortex-M0+ MSPM0 MCU portfolio. Measuring only 1.38 mm 2 , about the size of a black pepper flake, the wafer chip-scale package (WCSP) for the ...
STMicroelectronics has introduced the Teseo VI family of global navigation satellite system (GNSS) receivers aimed at high-volume precise positioning use cases. For the automotive industry, Teseo VI chips and modules will be core building blocks of ...
