News & Press Releases
Search results: 4,921 Output: 1-10
  1. RF Supply Nisshinbo NT9000 NT9001 NT9002 NT9003
    Nisshinbo Micro Devices Inc. announces the NT9000 , NT9001 , NT9002 , and NT9003 , diodes for microwave wireless power transfer (WPT). In recent years, microwave WPT technology has received significant global attention as a next-generation power ...
    Apr 10, 2026
  2. Vishay Intertechnology introduced a new compact, ready-to-use linear position sensor designed for high accuracy performance in demanding environments. Featuring non-contacting Hall Effect technology, the Vishay Sfernice 40 LHE delivers linearity ...
    Mar 27, 2026
  1. STMicroelectronics announced the Stellar P3E , the first automotive microcontroller (MCU) with built-in AI acceleration for automotive edge intelligence. Designed for future software-defined vehicles, the Stellar P3E simplifies multi-function ...
    Mar 24, 2026
  2. Toshiba Electronics Europe introduces the TPD7110F , an ideal diode controller designed to enable safe power control and flexible design in automotive systems. Target applications include body control modules (BCM), battery management systems ...
    Mar 18, 2026
  3. Vishay Intertechnology introduced a new tricolor LED that provides luminous intensity to 252 mcd at 5 mA for RGB displays and backlighting. Featuring common anode and separate cathode connections for the red, true green, and blue LED chips inside ...
    Mar 16, 2026
  4. Interfaces Wiznet WIZ-IP20 WIZ-IP55
    WIZnet is releasing ioPort, a new RJ45-style module series made to add Ethernet to embedded products with less PCB work and faster time-to-market. ioPort modules put the Ethernet chip inside the connector, so you can keep your base board simple ...
    Feb 20, 2026
  5. Toshiba Electronics introduces the TCD2400DG , a new lens reduction type CCD linear image sensor designed to meet the demanding requirements of modern optical inspection equipment. The new sensor features 4096 elements with a 7 µm pitch and ...
    Feb 19, 2026
  6. Supply Toshiba TCKE601RA TCKE601RL TCKE602RM TCKE603RA TCKE603RL
    Toshiba Electronics expands its electronic fuse (eFuse) lineup with the introduction of the 40 V TCKE6 series. The five new products are the TCKE601RA , TCKE601RL , TCKE602RM , TCKE603RA , and TCKE603RL . The eFuse ICs are suitable for use in ...
    Feb 16, 2026
  7. Building on decades of experience in serving embedded applications where low power, affordability and ease of development are critical, Microchip Technology has added PIC32CM PL10 MCUs to its PIC32C family of Arm Cortex-M0+ core devices. PL10 MCUs ...
    Feb 9, 2026
  8. Sensors Littelfuse LF21173TMR LF21177TMR
    Littelfuse, Inc. announced the launch of two next-generation omnipolar magnetic switches, the LF21173TMR and LF21177TMR . These devices combine Tunneling Magnetoresistance (TMR) and CMOS technologies in a compact LGA4 package, providing ultra-low ...
    Jan 28, 2026
