Circuits & Schematics
Search results: 2,319 Output: 1-10
  1. Gavin Watkins
    Expensive shortwave radios include beat frequency oscillators, so why not also add one to an inexpensive radio version? Broadcast shortwave (SW) radio use may be declining, but there are still lots of interesting signals to listen to between 1.6 ...
    Aug 25, 2026
  2. Luca Bruno
    This proposed design eliminates traditional additional requirements for AGC, AC coupling, and post amplification circuitry. This Design Idea presents a simple op-amp-based sine wave oscillator that directly generates a low-impedance bipolar output ...
    Aug 19, 2026
  1. Vishwas Vaidya
    A novel switch architecture caters to extended battery range coupled with robust protection and diagnostic strategies. For automotive control units, the smart output switches operating contactor coils, lamps, solenoids, PTC (positive temperature ...
    Aug 17, 2026
  2. Stephen Woodward
    This circuit enables you to generate remote control PWM test signals with a (very) generic (and cheap) chip. A recent Design Idea ( Ref. 1 ) illustrated the application of an interesting chip (the LTC6992 ) to remote control (RC) PWM test signal ...
    Aug 13, 2026
  3. Stephen Woodward
    Self-heated Darlingtion transistor pair linearly senses airflow using just two wires for both power in and signal out. Suppose we take a common TO-92 transistor and heat it to a constant temperature differential above ambient. The power input ...
    Aug 11, 2026
  4. Jayapal Ramalingam
    Front-panel push button controls can conveniently adjust a PCB-mounted internal potentiometer’s resistance. Digital potentiometers in conjunction with MCUs find common use in analog circuits. The processor can adjust the gain of an amplifier, ...
    Aug 11, 2026
  5. Stephen Woodward
    Minimal circuit converts input frequency to a precision current source that also accommodates grounded inputs. I recently had the opportunity to share a design ( Ref. 1 ) for frequency to current loop conversion using the versatile (if somewhat ...
    Aug 10, 2026
  6. Gavin Watkins
    One of my electronics interests is building radios, particularly those featured in older UK electronics magazines such as Practical Wireless, Everyday Electronics, Radio Constructor, and The Maplin Magazine. Most of those radios are designed to run ...
    Jul 29, 2026
  7. Mark Thoren
    I 2 C is a popular serial protocol for power controllers, ADCs and DACs, EEPROMs, and other devices. In certain data-acquisition and power-control situations, you must isolate the master from one or more slave devices for noise, grounding, or ...
    Jul 28, 2026
  8. David A. Johnson
    Circuits Beginners Vishay IRFD024 IRFD9020
    There are times when you would like to control a DC motor using a simple +5 V logic swing signal. The circuit below performs this feat and also includes an automatic motor braking circuit. When the input logic signal swings from 0 V to +5 V, the ...
    Jul 27, 2026
