Abstract This article explains why Bode plots are used to showcase the transfer function of a power supply loop. While there are load transient tests in the time domain, the results do not show other important information that a Bode plot does. ...
Power line communication (PLC) has been around for decades. It’s a foundational technology for smart grids and industrial networks. Yet, despite widespread deployments, it’s still widely misunderstood. As energy infrastructure expands ...
For some time, minicomputers were a dominant force in computing. But where do they stand now? The Electronic Design April 1970, Vol. 18, No. 9. cover article, The minicomputer: machine with an endless future, highlighted minicomputers. They had ...
Before a circuit designer decides on a particular power supply, he or she will first want to test it carefully. The data sheet for a switching regulator IC provides valuable information on how the complete power supply could behave in real life, as ...
Obtain tighter stop band impedance variance via the techniques detailed in this tutorial. Input impedances presented by lowpass and highpass filters in their respective stop bands are usually not controlled and can vary quite widely. Sometimes ...
An introduction to the access technologies that allow multiple users to share a common communications channel Access methods are multiplexing techniques that provide communications services to multiple users in a single-bandwidth wired or wireless ...
Having very large or very small duty cycles, especially at high switching frequencies, can cause timing violations, leading to degraded system performance. Abstract This article is the third article in a series where common switch-mode power supply ...
Choosing an R SENSE value that is too large or too small, as well as removing the filtering, can lead to worse system efficiency and degraded noise performance. Abstract This is the second article in a series where common switch-mode power supply ...
Improper inductor sizing and violation of the inductor saturation current rating can cause a wide variety of issues within DC-to-DC converters, two of which are audible ringing and overheating. Abstract This article is the first in a series where ...
In a famous episode of The Simpsons, Kelsey Grammar’s villainous Sideshow Bob protests the evils of television by holding the town of Springfield hostage. And as he appears on TV to deliver his fiendish monologue, he utters the immortal line, ...
