Circuits & Schematics
Search results: 2,275 Output: 1-10
  1. David A. Johnson
    This circuit uses a flat piezoelectric wafer, glued inside a plastic box, as a finger tap sensor. With each tap of a finger to the box holding the wafer, the circuit turns on and off AC or DC power to an external device. The circuit is powered by a ...
    May 7, 2026
  2. Hesam Moshiri
    Story Infrared remote controllers are everywhere around us. The majority of home appliances are controlled using infrared remote controls. In this article, we learn to build a device that can decode (almost) any IR remote control and use the ...
    May 7, 2026
  1. Stephen Woodward
    Op amps tend to make analog design easy. Maybe sometimes too easy? Don’t get me wrong. I like operational amplifiers. Some of my best friends are op amps. They embrace such a wide range of varied capabilities, including low noise, high power, ...
    May 7, 2026
  2. Sagar Saini
    Class D amplifier with a good performance and better sound quality. We can call it a Class D with Class A specs. Story I am a fan of audio technology as it is cleared from most of my articles. I always try some new ICs or audio related things here. ...
    May 6, 2026
  3. Stephen Woodward
    Combining an accurate temperature sensor with a standard digital multimeter can make an inexpensive, accurate, and useful thermometer. A recent Design Idea, BJT is accurate sensor for absolute temperature in Kelvin and Rankine ( Ref. 1 ), was based ...
    Apr 30, 2026
  4. Stephen Woodward
    Simple math implemented in a (very) simple circuit. What’s not to like? A very cool (also warm!) property of the base-emitter junction of (most) small signal BJTs is the ΔV BE temperature-sensing effect. ΔV BE temperature ...
    Apr 30, 2026
  5. Lapo Pieri
    Circuits Supply Texas Instruments LM5050-1 LM5050-2 CSD17501Q5A
    Given two batteries, it chooses the one to connect to the load based on the voltage measured at their poles. It can also be used to switch DC power supplies. The growing demand for portable devices capable of working where there is no power grid or ...
    Apr 28, 2026
  6. Jayapal Ramalingam
    Circuits such as the design described here implement useful tools for a diversity of calibration and testing applications A two-wire loop current generator is a useful tool for the testing, calibration and commissioning of current-to-pressure (I/P) ...
    Apr 24, 2026
  7. David Johnson-Davies
    Figure 1 shows a simple tester, based on an ATtiny202 , a piezo buzzer, and an LED, for checking circuit wiring or tracing out the tracks on a PCB: Figure 1. The Tiny Continuity Tester based on an ATtiny202. The piezo speaker is on the reverse of ...
    Apr 16, 2026
  8. Boris Landoni
    Let’s melt metals using the ZVS (Zero Voltage Switching) technique applied to a 1,000 W RLC resonant circuit. Have you ever wondered how intense the electromagnetic fields surrounding us can be? This is a relevant question, considering we are ...
    Apr 15, 2026
