Circuits & Schematics
Search results: 2,298 Output: 1-10
  1. Jayapal Ramalingam
    Converting frequency signals to loop current signals creates an economical result for process industry applications. Process industry applications commonly employ multiple motors. Their speeds are monitored by tachometers using magnetic pickups ...
    Jul 8, 2026
  2. David A. Johnson
    This page provides a detailed explanation of how the modified cascode light receiver circuit operates. The cascode technique in conjunction with an inductive load provides very high current to voltage conversion as well as very high speed. Upper ...
    Jul 8, 2026
  1. Stephen Woodward
    An only slightly less simple followup circuit also ratios sensor capacitance to a reference capacitor to measure micrometers this time linearly. A few weeks ago, Design Ideas published a simple circuit of mine that provides an analog interface to ...
    Jun 25, 2026
  2. Mike (mixos)
    The circuit shown in Figure 1 is a complete microphone signal conditioning system based on a single SSM2166 integrated circuit. Designed primarily for voiceband applications, this integrated circuit provides amplification, RMS detection, limiting, ...
    Jun 25, 2026
  3. Nick Cornford
    Here’s a neat and novel way of using a long-tailed pair to drive not just two but three LEDs. As everyone knows, rainbows always have pots of gold at their ends. This Design Idea reverses that, starting with a pot (no gold, alas) and ending ...
    Jun 24, 2026
  4. Stephen Woodward
    Circuits for converting 4 to 20 mA analog current loop signals to 0 to 20 mA may be hot topics, but hot implementations of those circuits are not. Circuit designs for conversion of 4 to 20 mA analog current loop signals, which are ubiquitous in ...
    Jun 23, 2026
  5. David A. Johnson
    This circuit uses a few FETs and logic devices to down convert a DC voltage to about one half its value. Materials on the topic Datasheet Fairchild MM74C14 Datasheet Diodes ZVN2106A Datasheet Diodes ZVP2106A discovercircuits.com
    Jun 17, 2026
  6. Stephen Woodward
    The ubiquity of the 4 to 20 mA current loop in analog process monitoring and control creates possibilities for peculiar designs of circuits for unusual accessory functions. Figure 1 shows an example. It does precision conversion of 4-20 mA to 0-20 ...
    Jun 15, 2026
  7. Hesam Moshiri
    This project presents the design and implementation of a dual-fan PWM cooling circuit, integrating a compact and efficient power supply with intelligent fan speed regulation. The circuit consists of two main parts: a 6 W isolated flyback converter ...
    Jun 15, 2026
  8. David A. Johnson
    Circuits Beginners Diodes ZVN2106A ZVP2106A
    This circuit can produce high speed output signals with fast rise and fall times. The unique charge pump action allows the voltage of the upper P-ch device to range from millivolts to hundreds of volts. The output current is only limited by the ...
    Jun 9, 2026
