This silly simple circuit cancels out potentially serious digital potentiometer zero- and full-scale errors. Everybody (well, most everybody) knows that digipots tend to be more accurate when used as variable voltage dividers (i.e., in ...
Abstract A new generation of 4-switch buck-boost controllers enables power system design with very high efficiency and high power density by using inductor DC resistance (DCR) current-sensing techniques. This article explains the benefits of ...
You can install the bench-top accessory in Figure 1 between a variable-voltage bench power supply and a breadboard or UUT (unit under test) to protect against accidental overvoltage and reverse polarity. It draws its power from the supply and ...
A new report confirms what most of us already knew that data center energy demand is rapidly outpacing supply. And for those who’ve heard of the smart grid so 99% of us) the concurrent issue is no less surprising delivering the electricity ...
How to design a simpler filter (or filter-like circuit) with a varying time constant dependent on what kind of waveform is fed to it. Discussions with some former coworkers have focused on how to design a filter or circuit with filter-like ...
As AI data centers sprout up across the globe, we’ve begun grappling with AI’s not-so-hidden secret it has a voracious, unquenchable appetite for power. Some cities have even passed moratoriums on new AI data centers because of their ...
Butterworth response circuits come in both low- and high-pass versions, as well as ideal, Sallen-Key, emitter follower and DC accurate variants. Many decades ago, I published a Design Idea about using equal value resistors and capacitors to ...
Gray codes, also known as reflected binary codes, offer a clever way to minimize errors when digital signals transition between states. By ensuring that only one bit changes at a time, they simplify hardware design and reduce ambiguity in ...
The frequency response of a Butterworth filter is not supposed to have any peaking. SPICE claims the contrary. I came across an online datasheet for some op-amps where I found two schematics that intrigued me. Screen-shotting them together resulted ...
Abstract This article explains why Bode plots are used to showcase the transfer function of a power supply loop. While there are load transient tests in the time domain, the results do not show other important information that a Bode plot does. ...
