Search results: 878 Output: 1-10
  1. Bill Schweber
    We’ve come to expect the U.S.-based global positioning system (GPS) to be available and ubiquitous for the countless military, commercial, and consumer applications dependent on it. Its diverse uses represent a huge leap from its original ...
    May 28, 2026
  2. William Wong
    Magnetic cores had some interesting uses, but a lot has changed in memory technology. This iteration of Electronic Design: Now and Then was inspired when I was reading Using Magnetic Cores in Computers from our archives. This article was originally ...
    May 20, 2026
  1. Jason Lomberg
    AI might be replacing jobs at an exponential rate, but a significant percentage of people would not only be OK with AI co-workers, but an AI boss. That’s according to a Quinnipiac University national poll which surveyed usage, experience, and ...
    Apr 28, 2026
  2. Jason Lomberg
    At a time when AI data centers are expanding astronomically to provide the otherworldly computing power needed to train AI models, you might be wondering about the psychological effect of exposing ourselves to an artificial entity that’s ...
    Apr 28, 2026
  3. Bob Witte
    There are several ways to evaluate the bandwidth of a signal in the time domain and frequency domain. Previously we looked at the classic relationship of rise time (t R ) and bandwidth (f 3dB ) [ Ref 1 ], captured by this equation: Eric Bogatin ...
    Apr 23, 2026
  4. Bob Witte
    The term bandwidth is used and abused in many situations. I recall one meeting where the word was used to refer to: the frequency content of a particular signal, the frequency response of a specific circuit, the speed of our local area network and ...
    Apr 23, 2026
  5. Jordan Dimitrov
    This design based on an SR latch and two RC networks is, unlike many alternative solutions, neither complex nor expensive. Single and differential capacitance sensors are widely used to measure linear and angle displacement, pressure, proximity, ...
    Apr 22, 2026
  6. Damian Bonicatto Phoenix Bonicatto
    Multicore processing boosts performance and energy efficiency in many coding situations. Bare-metal algorithms further enhance these benefits. Many embedded firmware engineers have seemingly not yet tried multicore processing. Using processors with ...
    Apr 17, 2026
  7. Kurk Mathews Luis Onofre Lazaro
    Measurement Supply Analog Devices LTC7890 LTC7891 LTC7892 LTC7893
    Abstract This article discusses the need for precise gate voltage control and accurate gate measurements when using gallium nitride field-effect transistors (GaN FETs). High-side gate measurements taken with advanced isolated probes are compared to ...
    Apr 13, 2026
  8. Luca Bruno
    Drivers Light Fairchild BC550C BC557B
    The circuit in Figure 1 combines a V BE -referenced current source with a current mirror to implement a simple two-terminal, fully floating LED current sink or source. This approach is well-suited for applications in which tight current accuracy is ...
    Apr 1, 2026
