Search results: 888 Output: 1-10
  1. Abe Ibraheim Kenneth Armijo Piyu Dhaker
    Having very large or very small duty cycles, especially at high switching frequencies, can cause timing violations, leading to degraded system performance. Abstract This article is the third article in a series where common switch-mode power supply ...
    Jul 6, 2026
  2. Abe Ibraheim Kenneth Armijo Piyu Dhaker
    Improper inductor sizing and violation of the inductor saturation current rating can cause a wide variety of issues within DC-to-DC converters, two of which are audible ringing and overheating. Abstract This article is the first in a series where ...
    Jul 1, 2026
  1. Jason Lomberg
    In a famous episode of The Simpsons, Kelsey Grammar’s villainous Sideshow Bob protests the evils of television by holding the town of Springfield hostage. And as he appears on TV to deliver his fiendish monologue, he utters the immortal line, ...
    Jun 30, 2026
  2. Frederik Dostal
    Introduction Switch-mode power supplies based on the buck (step-down) converter principle are widely used in all electronic applications. They do not require a transformer, just a simple coil to efficiently convert a high voltage to a low voltage. ...
    Jun 24, 2026
  3. Aubrey Kagan
    In my first blog about calibration [ 1 ], I discussed calibrating inputs using techniques that tolerated offsets by simply including them in the measurements. In this blog I will look at nullifying the offsets. The initial approach is to build in ...
    Jun 17, 2026
  4. Frederik Dostal
    Abstract This article explains the unique considerations and challenges associated with utilizing GaN switches in switch-mode power supplies. A solution is presented in the form of a specialized GaN driver that provides the necessary functions for ...
    Jun 17, 2026
  5. Aubrey Kagan
    In the comments to my series of blogs on temperature measurement on the late, lamented Microcontroller Central, there was some feeling that a blog on calibration of analog IO might be a good idea. Let me start by taking you back to some high school ...
    Jun 16, 2026
  6. John Dunn
    Upside-down mounting can deliver inductance upsides for surface mount passives and other components. Please visualize the structure of a surface mount resistor as shown in the Figure 1. Figure 1. Surface mount resistor constituents include this ...
    Jun 15, 2026
  7. Peter Demchenko
    Supply Vishay BZX85V200
    This moral of this story: any promises of protection and safety should be double-checked for validity. Surge (over-voltage) protection is a rather frequent function, but implementing it robustly is not a very simple task. Recently, I stumbled upon ...
    Jun 4, 2026
  8. Bill Schweber
    We’ve come to expect the U.S.-based global positioning system (GPS) to be available and ubiquitous for the countless military, commercial, and consumer applications dependent on it. Its diverse uses represent a huge leap from its original ...
    May 28, 2026
