Circuits & Schematics
Search results: 2,173 Output: 1-10
  1. Nick Cornford
    We recently saw how certain audio power amplifiers can be used as oscillators ( Ref. 1 ). This Design Idea shows how those same parts can be used for simple amplitude modulation, which is trickier than it might seem. The relevant device is the ...
    Aug 20, 2025
  2. Raju Baddi
    LEDs need current to illuminate, and current usually flows through a power supply to an LED. A typical LED-driver circuit uses a transistor to provide current and a series resistor to decrease the voltage you apply to the LED. Unfortunately, the ...
    Aug 20, 2025
  1. Ron Patrick
    The classical Schmitt trigger circuit that you'll find in textbooks provides some noise immunity, such as for the front end of magnetic pickup in position-sensor circuits (Figure 1a). You adjust the two threshold levels using R 1 and R 2 or R 2 ...
    Aug 19, 2025
  2. Stephen Woodward
    Precision-matched resistors, diode pairs, and bridges are generic items. But sometimes an extra critical application with extra tight tolerances (or an extra tight budget) can dictate a little (or a lot) of DIY. Figure 1’s matchmaker circuit ...
    Aug 19, 2025
  3. Jim McLucas
    Stephen Woodward, a prolific circuit designer with way more than 100 published Design Ideas (DIs), had his “80 MHz VFC with prescaler and preaccumulator” [ 1 ] published on October 17, 2024, as a DI on the EDN website. Upon reading his ...
    Aug 19, 2025
  4. Stephen Woodward
    We’ve seen lots of interesting conversations and Design Idea (DI) collaboration devising circuits for power switching using inexpensive (and cute!) momentary-contact SPST pushbuttons. A recent and interesting extension of this theme by ...
    Aug 11, 2025
  5. Christopher Paul
    Implementing a simple digital-to-analog converter (DAC) by cascading a single pulse width modulator (PWM) and an analog low-pass filter is nothing new. Nor is applying to a filter the sum of the outputs of a most significant 2 N -count PWM and a ...
    Aug 11, 2025
  6. Stephen Woodward
    “Two halves make a whole” is a very old and often true maxim. For example, it’s almost always true when said about AC phase angle power control. You rarely want significant alternating half-cycle asymmetry due to the (usually ...
    Aug 4, 2025
  7. John Dunn
    Circuits Supply onsemi FOD410 FOD4108 FOD4116 FOD4118
    Check out this link for On Semiconductor’s datasheet for a line of “Zero-Cross Optocoupled Triac Drivers.” The ability to zero-cross when turning on AC line voltage to some loads may be advantageous. The following sketch in Figure ...
    Aug 4, 2025
  8. David Magliocco
    A simple circuit can improve the dynamic performance of a phototransistor for use in low- to medium-speed applications as fast as 100 kbps, such as optical isolation of an RS-232C serial line (Figure 1). In low-cost applications that require high ...
    Jul 30, 2025
