Circuits & Schematics
Search results: 2,303 Output: 1-10
  1. David A. Johnson
    Version 1 A single lithium ion battery cell needs 4.2 V from a current source to insure it is fully charged. A solar panel with just enough individual cells wired in series to produce the needed voltage would be more efficient than one with more ...
    Jul 16, 2026
  2. Stephen Woodward
    The iconic LM2917 tackles frequency-to-current conversion with (very) few externals. Almost exactly 50 years ago in June 1976, to be precise National Semiconductor introduced the LM29x7 series, offering deceptively simple monolithic solutions to a ...
    Jul 16, 2026
  1. David A. Johnson
    Circuits Supply Toshiba TC4S584F,LF
    There are many applications when a remote switch’s on/off status needs to be monitored. Reed relay sensors, toggle control switches and security alarms contacts are just a few examples. Routing a switch directly to a computer system hundreds ...
    Jul 15, 2026
  2. Stephen Woodward
    A self-heated Darlington transistor pair makes a simple, sensitive, and sturdy airflow sensor. But first an annoying non-linearity needs unbending. If you take a self-heated transistor in a TO-92 package and force it to hold a constant temperature ...
    Jul 14, 2026
  3. Jayapal Ramalingam
    Converting frequency signals to loop current signals creates an economical result for process industry applications. Process industry applications commonly employ multiple motors. Their speeds are monitored by tachometers using magnetic pickups ...
    Jul 8, 2026
  4. Stephen Woodward
    Circuits Measurement Texas Instruments SN74HC4066 TLV197-Q1 TLV9051
    A linearized output is a useful elaboration of a capacitive sensor design. But what if the circuit is located a significant distance from the control electronics? Recently, Design Ideas included a circuit ( Ref. 1 ) that comprised a simple analog ...
    Jul 8, 2026
  5. David A. Johnson
    This page provides a detailed explanation of how the modified cascode light receiver circuit operates. The cascode technique in conjunction with an inductive load provides very high current to voltage conversion as well as very high speed. Upper ...
    Jul 8, 2026
  6. Stephen Woodward
    An only slightly less simple followup circuit also ratios sensor capacitance to a reference capacitor to measure micrometers this time linearly. A few weeks ago, Design Ideas published a simple circuit of mine that provides an analog interface to ...
    Jun 25, 2026
  7. Mike (mixos)
    The circuit shown in Figure 1 is a complete microphone signal conditioning system based on a single SSM2166 integrated circuit. Designed primarily for voiceband applications, this integrated circuit provides amplification, RMS detection, limiting, ...
    Jun 25, 2026
  8. Nick Cornford
    Here’s a neat and novel way of using a long-tailed pair to drive not just two but three LEDs. As everyone knows, rainbows always have pots of gold at their ends. This Design Idea reverses that, starting with a pot (no gold, alas) and ending ...
    Jun 24, 2026
