Circuits & Schematics
Search results: 2,139 Output: 1-10
  1. Manoj Kumar
    When talking about standalone single cell battery chargers only one popular name came into my mind that is our versatile Li-Ion/Li-Po TP4056 battery charger. Which is vastly available and has a lot of features related to battery protection. The ...
    Jun 4, 2025
  2. Stephen Woodward
    The typical regulator output network Many voltage regulator chips, both linear and switching, use the same basic two-resistor network for output voltage programming. Figure 1 illustrates this feature in a typical switching (buck type) regulator, ...
    Jun 2, 2025
  1. Anirban Chatterjee
    Semiconductor laser diodes (SLDs) are often packaged with a photodiode. The output current from this photodiode can be monitored to regulate the output power intensity of the laser diode. SLDs, however, are prone to pathological drifts, such as ...
    May 29, 2025
  2. Stephen Woodward
    The TL431 has been around for nearly 50 years. During those decades, while primarily marketed as a precision adjustable shunt regulator, this legacy device also found its way into alternative applications. These include voltage comparators, audio ...
    May 22, 2025
  3. Stephen Woodward
    One classic set you’ll see in most гvintage mystery movies is an interrogation room with a “two-way” mirror in one wall. This cool gadget lets the witnesses see the suspects from another room while the suspects can see only ...
    May 22, 2025
  4. Stephen Woodward
    Frequent contributor Nick Cornford recently shared design ideas incorporating cool circuits for linear-in-pitch voltage-controlled oscillators (LPVCOs): Revealing the infrasonic underworld cheaply: Part 1 ( Ref. 1 ) and Part 2 ( Ref. 2 ) A ...
    May 21, 2025
  5. Christopher Paul
    Circuits Supply Texas Instruments SN74LVC2G14 SN74LVC14A TLV333
    A recent Design Idea, “Three discretes suffice to interface PWM to switching regulators”( Reference 1 ), demonstrated one way to use PWM to control the output of a typical switching voltage regulator. There were some discussions in the ...
    May 20, 2025
  6. Nick Cornford
    In Part 1 of this Design Idea [ 1 ], we saw how a standard electret microphone capsule can be persuaded to detect infrasonic signals down to a fraction of a Hertz by adding some fairly simple equalization. In this second and concluding part, we ...
    May 20, 2025
  7. Nick Cornford
    Electrets aren’t only used as audio pickups. For decades, they have been employed in security systems to detect unexpected changes of air pressure within rooms, while more recently they can be found in vapes as suck-sensors (or, more ...
    May 20, 2025
  8. Cor van Rij
    In April 2012, EDN published a circuit by John Fattaruso ( Ref. 1 ) that lets you quickly measure the drain-source saturation current and the pinch-off voltage of both an N-JFET and a P-JFET. The pinch-off voltage (V P ) is measured by inserting a ...
    May 15, 2025
