Search results: 843 Output: 1-10
  1. Frederik Dostal
    Supply Analog Devices LT4422 LT4423
    Abstract Robust systems often allow multiple power sources. When different power sources are used to power a device, switches need to be implemented to separate the power supplies from each other to avoid damage. This can be accomplished with ...
    Nov 18, 2025
  2. T.K. Hareendran
    Electronic components Automation Beginners Vishay TCST1103/1202/1300 TCRT5000
    A homing sensor is a device used in certain machines to detect a fixed reference point, allowing the machine to determine its exact starting position. When powered on, the machine moves until it triggers the sensor, so it can accurately track ...
    Nov 13, 2025
  1. Stephen Woodward
    It’s just a fact of life. A BJT wired in common emitter, even after compensating for the effects of device and temperature variations, still isn’t a perfect current source. One of the flaws in the ointment is the Early effect of ...
    Nov 7, 2025
  2. Damian Bonicatto Phoenix Bonicatto
    For the past couple of years, I’ve been using AI to assist in the design of my hardware and firmware projects. The experience has generally been good, even though the outcome isn’t always useful. So, I’m presenting a short summary ...
    Oct 30, 2025
  3. John Dunn
    High school trigonometry combined with four-quadrant multipliers can be exploited to yield sinusoidal frequency doublers. Nothing non-linear is involved, which means no possibly strident filtering requirements. Starting with some sinusoidal signal ...
    Oct 11, 2025
  4. T.K. Hareendran
    Hybrid relays are changing the way we think about switching inside electronic circuits. By combining the fast response of solid-state components with the reliability of mechanical contacts, these devices offer the best of both worlds. Whether you ...
    Oct 6, 2025
  5. Damian Bonicatto Phoenix Bonicatto
    Increasing ADC resolution Many electronic designs contain an ADC, or more than one, to read various signals and voltages. Often, these ADCs are included as part of the microcontroller (MCU) being used. This means, once you pick your MCU, you have ...
    Sep 30, 2025
  6. Michael Wyatt
    A Planet Analog article, “2N3904: Why use a 60-year-old transistor?” ( Ref. 1 ) by Bill Schweber, inspired some interest in this old transistor and how it’s commonly used, and if any uncommon uses might exist. Here’s one we ...
    Sep 28, 2025
  7. T.K. Hareendran
    This is just an ultra-quick blog post about a nostalgic IC: µPC1237. It’s a timeless bipolar analog IC from NEC designed for protecting stereo audio power amplifiers and loudspeakers. I used to see this awesome chip all the time in the ...
    Sep 23, 2025
  8. Christopher Paul
    The typical anti-log circuit The basic anti-log amplifier looks like the familiar circuit of Figure 1. Figure 1. The typical anti-log circuit has uncertainties related to the reverse current, I S , and is sensitive to temperature. The approximate ...
    Sep 22, 2025
