Search results: 748 Output: 1-10
  1. Modern measurement systems often operate with single 5-V power supplies, yet their input signals may have large common-mode voltages that exceed the supply by tens or hundreds of volts. Also, unless the converter is driven differentially, the noise ...
    06-05-2024
  2. Many precision test-and-measurement and high-speed analog applications require an exact targeted voltage to be delivered to the device under test or intended load to accurately analyze the device. Design and test engineers are well-aware that this ...
    29-04-2024
  1. Despite massive, large-scale integration being ubiquitous in contemporary electronic design, discrete MOSFETs in the classic CMOS totem pole topology are still sometimes indispensable. This makes tips and tricks for driving them efficiently with ...
    25-04-2024
  2. Supply Analog Devices ADP2147 MAX20480
    Abstract This article discusses the use of dynamic voltage scaling (DVS) to achieve precise voltage regulation. DVS is a process that adjusts the output voltage slightly higher or lower in anticipation of load transients. The article examines how ...
    23-04-2024
  3. FinFETs redefined chip design when they came onto the scene more than a decade ago. While these nonplanar transistors are still the unofficial industry standard, they may be nearing the end of their life. So, electronics engineers may need to ...
    10-04-2024
  4. A recent trend in the design of portable devices has been to use ceramic capacitors to filter DC/DC converter inputs. Ceramic capacitors are often chosen because of their small size, low equivalent series resistance (ESR) and high RMS current ...
    08-04-2024
  5. Supply Maxim MAX17577 MAX17580
    Introduction Electronic equipment uses predominantly positive voltage rails for power. Occasionally, some negative voltage rails are also used. For this reason, negative (or inverting) output DC/DC converter solutions are not as common as their ...
    04-04-2024
  6. Introduction A switching regulator converts an input voltage to a higher or lower output voltage. For this, an inductor is used to store energy temporarily. The size of this inductor depends on the switching frequency of the switching regulator as ...
    02-04-2024
  7. Introduction Wide bandgap power semiconductor devices like Silicon Carbide (SiC) MOSFETs are enjoying growing popularity in many modern power electronic applications like E-mobility and renewable energy. Their extremely fast switching speed ...
    22-03-2024
  8. When you include a power op amp, such as PA05 from Apex Microtechnology, in your design, it is desirable to minimize the supply-to-output differential to a minimum to reduce power dissipation and to fully exploit the amplifier's output range. ...
    19-03-2024
