Circuits & Schematics
Search results: 2,261 Output: 1-10
  1. Doctor Volt
    DIY Laser Scanning Microscope made from a defective Blu-Ray Player. A Blu-ray player must be able to detect the microscopically tiny pits on DVDs in order to play back a film. Therefore, the question arises: Can a Blu-ray player also see other ...
    Apr 1, 2026
  2. Jayapal Ramalingam
    In process industries, field contacts from pressure, temperature, flow switches, limit switches, push buttons, etc., are read by programmable logic controllers and/or distributed control systems (PLC/DCS) through digital input modules. They are ...
    Mar 27, 2026
  1. Stephen Woodward
    For decades, I’ve had a fascination with voltage-to-frequency converters and the 555 analog timer chip, and therefore a double obsession with VFCs based on the 555. In fact, my first Design Ideas (DI) submission (in 1974) was for a 555 VFC. ...
    Mar 27, 2026
  2. Nick Cornford
    The ovens in this two-part Design Idea (DI) can’t even warm that leftover half-slice of pizza, let alone cook dinner, but they can keep critical components at a constant temperature. In the first part, we’ll look at a purely analog ...
    Mar 26, 2026
  3. Stephen Woodward
    The pages of Design Ideas (DIs) have recently been awash in a veritable cascade of designs for variable frequency oscillators with frequency ranges tunable over multiple decades: Self-oscillating sawtooth generator spans 5 decades of frequencies ( ...
    Mar 26, 2026
  4. Hesam Moshiri
    This project is an ultrasonic range finder built using the RP2040 Zero board and a 3.2-inch TFT display. It utilizes the RCWL-1655 sensor, which operates similarly to the popular HC-SR04, to measure distances ranging from 20 cm to 300 cm. The ...
    Mar 19, 2026
  5. Hesam Moshiri
    A tiny DC to DC buck converter board is useful for many applications, especially if it could deliver currents up to 3 A (2 A continuously without heatsink). In this article, we will learn to build a small, efficient, and cheap buck converter ...
    Mar 18, 2026
  6. David A. Johnson
    A while back I was challenged by a visitor to the website. He needed a very loud sweeping siren type audio sound generator powered by 3 V. He tried some of the commercial sirens but they were not very loud when powered by 3 V. He also said that ...
    Mar 17, 2026
  7. Uwe Schüler
    It is well known that a 555 timer in astable mode can be frequency modulated by applying a control voltage (CV) to pin 5. The schematic on the top of Figure 1 shows this classic 555 VCO. Modulating pin 5 has some severe drawbacks: The control ...
    Mar 13, 2026
  8. Nick Cornford
    This two-part Design Idea (DI) follows on from a couple of previous articles relating to 100-Ω platinum resistance temperature detectors (Pt100 RTDs). The first of those (which we’ll call Ref 1 ) used a simple current-driven bridge to give an ...
    Mar 13, 2026
