Circuits & Schematics
Search results: 2,216 Output: 1-10
  1. John L. Waugaman
    The circuit presented by Cor van Rij ( Ref. 1 ) for characterizing JFETs is a clever solution. Noteworthy is the use of a five-pin test socket wired to accommodate all of the possible JFET pinout arrangements. This idea uses that socket arrangement ...
    Nov 26, 2025
  2. Christopher Paul
    A simple current source It has long been known that the simple combination of a depletion-mode MOSFET (and before these were available, a JFET) and a resistor made a simple, serviceable current source such as that seen on the right side of Figure ...
    Nov 25, 2025
  1. Stephen Woodward
    A classic nonlinear analog function is the squaring circuit. It’s useful in power sensing, frequency multiplication, RMS computation, and many other odd jobs around the lab bench. Figure 1. The squaring amplifier that is fast, ...
    Nov 25, 2025
  2. David A. Johnson
    By changing the supply voltage fed to a classic 4584 Schmitt trigger type oscillator, the oscillator frequency can be changed over a range of 50:1. A 74HCU04 inverter is used at the output of the 4584 to maintain a constant TTL logic level signal. ...
    Nov 24, 2025
  3. Simon Bramble
    Abstract This article describes the use of a load dump protection circuit to prevent accidental overvoltage/reverse-voltage conditions during prototyping. This simple circuit can prevent hours of rework caused by momentary lapses of concentration ...
    Nov 21, 2025
  4. Hesam Moshiri
    The isolated AC-to-DC flyback converter is the most commonly used power supply type for home and industrial devices. Fear of the main voltage and complexity of calculations cause electronic beginners and enthusiasts to procrastinate DIY such ...
    Nov 17, 2025
  5. Jim McLucas
    Circuits Measurement Texas Instruments CD74HC14 SN74LVC1G14 74LVC1G74 TLA431 TLV9162
    “Facts are stubborn things” (John Adams, et al). I added two 50-ohm outputs to the schematic of my published voltage-to-frequency converter (VFC) circuit [ 1 ] (Figure 1). Then, I designed a PCB, purchased the (mostly) surface-mount ...
    Nov 14, 2025
  6. Joribo
    Generating ozone and negative ions in the air can be done by a corona discharge. For this we can use a sharp tip of negative polarity, acting against a flat metal part of positive or neutral potential. The device generates negative air ions and ...
    Nov 12, 2025
  7. Hesam Moshiri
    Without a doubt, FM transmitter and receiver are among the top favorite electronic project topics, however, building a digital FM transmitter can be a challenging project for electronics enthusiasts. The transmitter can then be connected to a ...
    Nov 6, 2025
  8. Stephen Woodward
    Recently, we’ve seen Design Ideas for programmable current sources with improved accuracy using the LM3x7 series of three-legged regulators. These designs also take advantage of those classic devices’ built-in anti-overheating features. ...
    Oct 28, 2025
