Search results: 863 Output: 1-10
  1. Thomas Kugelstadt
    Interfaces Texas Instruments SN65HVD23 SN65HVD24
    Modern high-speed RS-485 data links are pushing the envelope to the absolute breaking point with regards to data rate versus cable length. Applications include position encoders, traffic monitoring, seismic networks, and GPS transceivers. Data ...
    Mar 13, 2026
  2. Bill Schweber
    We’re all familiar with thermally activated fuses, where the conducting element self-heats due to current flow, melts at a defined current value, and breaks the flow path. They are simple in concept (although they have their own subtleties, ...
    Mar 5, 2026
  1. Bill Schweber
    I have always been intrigued by the many ways scientists and engineers have devised to sense basic physical parameters such as temperature, pressure, voltage, current, and electric fields, to cite just a few. In some cases, the challenge is the ...
    Mar 4, 2026
  2. John Dunn
    Any semiconductor has limits on how much voltage, how much current, and for how much time combinations of voltage and current can be supported in normal usage. Sometimes that information is provided as part of the device’s datasheet, and ...
    Feb 28, 2026
  3. Simon Bramble
    Abstract This article describes a circuit that facilitates the measurement of currents from amps to hundreds of amps with a high degree of precision. Introduction There are many applications that require the measurement of current. Many digital ...
    Feb 24, 2026
  4. Alain Stas
    With the trend toward miniaturization, temperature effects in power electronics are more pronounced than ever. If you’re dealing with temperature fluctuations in your circuit, you may need a stabilization system to keep the temperature ...
    Feb 19, 2026
  5. Bob Zollo
    I’ve been working with dc power supplies and batteries for over 30 years now and every day I employ Ohm’s Law, V = I R, to solve some problem or make some calculation related to dc power. If current is flowing, then there’s a ...
    Feb 19, 2026
  6. Michael Wyatt
    Could a simple passive RC network without any transformers, inductors, switches, or non-linear components produce a voltage gain? Well, it’s not “free energy,” however, yes, and can even use the same value resistor and capacitor ...
    Feb 18, 2026
  7. Bonnie Baker
    High-resolution mixed-signal devices present an interesting challenge as you try to find the right voltage-reference design. Although no universal approach exists for these voltage-reference designs, the circuit in Figure 1 presents an interesting ...
    Feb 6, 2026
  8. Tommy Liu
    Particulate matter (PM2.5) monitoring is a key public-health metric. Vehicle- and drone-mounted sensors can expand coverage, but many existing systems are too costly for broad deployment. This Design Idea (DI) presents a prototype PM2.5 sensing and ...
    Jan 28, 2026
