Circuits & Schematics
Search results: 2,221 Output: 1-10
  1. Stephen Woodward
    This Design Idea (DI) offers an alternative solution for an application borrowed from frequent DI contributor R. Jayapal, presented in: “A 0-20 mA source current to 4-20 mA loop current converter” ( Ref. 1 ). It converts a 0/20 mA ...
    Dec 6, 2025
  2. Jayapal Ramalingam
    A 4 to 20 mA loop current is a popular terminology with Instrumentation/Electronics engineers in process industries. Field transmitters like pressure, temperature, flow, etc., give out 4 to 20 mA current signals corresponding to the respective ...
    Dec 5, 2025
  1. Christopher Paul
    “Gold-plated” without the gold plating Alright, I admit that the title is a bit over the top. So, what do I mean by it? I mean that: The application of PWM control to a regulator does not significantly degrade the inherent DC accuracy ...
    Dec 4, 2025
  2. Tom Roberts
    It's important to properly sequence the bias applied to an RF/microwave GaAs FET or a MMIC (monolithic-microwave-IC) amplifier. These devices are extremely sensitive to drain and gate voltage levels as well as to the order in which these biases ...
    Dec 3, 2025
  3. Alfredo Saab
    Voltage transients on low-voltage power lines can sometimes attain amplitudes many times the nominal voltage level. That behavior often calls for protection against the application of improper power levels. The usual way to protect sensitive ...
    Dec 1, 2025
  4. John L. Waugaman
    The circuit presented by Cor van Rij ( Ref. 1 ) for characterizing JFETs is a clever solution. Noteworthy is the use of a five-pin test socket wired to accommodate all of the possible JFET pinout arrangements. This idea uses that socket arrangement ...
    Nov 26, 2025
  5. Christopher Paul
    A simple current source It has long been known that the simple combination of a depletion-mode MOSFET (and before these were available, a JFET) and a resistor made a simple, serviceable current source such as that seen on the right side of Figure ...
    Nov 25, 2025
  6. Stephen Woodward
    A classic nonlinear analog function is the squaring circuit. It’s useful in power sensing, frequency multiplication, RMS computation, and many other odd jobs around the lab bench. Figure 1. The squaring amplifier that is fast, ...
    Nov 25, 2025
  7. David A. Johnson
    By changing the supply voltage fed to a classic 4584 Schmitt trigger type oscillator, the oscillator frequency can be changed over a range of 50:1. A 74HCU04 inverter is used at the output of the 4584 to maintain a constant TTL logic level signal. ...
    Nov 24, 2025
  8. Simon Bramble
    Abstract This article describes the use of a load dump protection circuit to prevent accidental overvoltage/reverse-voltage conditions during prototyping. This simple circuit can prevent hours of rework caused by momentary lapses of concentration ...
    Nov 21, 2025
