An interesting analog design problem is the precision current source. Many good designs are available, but most are the three-wire types that can be used as a positive (see Figure 1) or a negative (Figure 2) polarity source, but not both from the ...
This project features a compact and efficient DC-DC buck-boost converter, based on the XL6019 chip, designed to maintain a stable 12 V output over a wide input voltage range of 9 V to 30 V. The XL6019 is a high-performance switching regulator ...
An adjustable load in Figure 1 provides a constant-current load for testing power supplies and batteries. It allows you to set the load current to up to 1.05 A, using a potentiometer, and displays the current on a three-digit LED display controlled ...
I have modified several commercial solar garden lights over the years. I switch out the LED, solar panel, battery pack and control circuit. The result is a much better overall light. One of my disappointments in using store-bought garden light ...
This Design Idea (DI) offers an alternative solution for an application borrowed from frequent DI contributor R. Jayapal, presented in: “A 0-20 mA source current to 4-20 mA loop current converter” ( Ref. 1 ). It converts a 0/20 mA ...
A 4 to 20 mA loop current is a popular terminology with Instrumentation/Electronics engineers in process industries. Field transmitters like pressure, temperature, flow, etc., give out 4 to 20 mA current signals corresponding to the respective ...
“Gold-plated” without the gold plating Alright, I admit that the title is a bit over the top. So, what do I mean by it? I mean that: The application of PWM control to a regulator does not significantly degrade the inherent DC accuracy ...
It's important to properly sequence the bias applied to an RF/microwave GaAs FET or a MMIC (monolithic-microwave-IC) amplifier. These devices are extremely sensitive to drain and gate voltage levels as well as to the order in which these biases ...
Voltage transients on low-voltage power lines can sometimes attain amplitudes many times the nominal voltage level. That behavior often calls for protection against the application of improper power levels. The usual way to protect sensitive ...
The circuit presented by Cor van Rij ( Ref. 1 ) for characterizing JFETs is a clever solution. Noteworthy is the use of a five-pin test socket wired to accommodate all of the possible JFET pinout arrangements. This idea uses that socket arrangement ...
